Changes the labels of a statically configured Ethernet pseudowire for a VPWS.
| vpws_name |
Specifies the VPWS for which you are configuring a peer. |
| peer |
Specifies the peer IP address. |
| ipaddress |
Specifies the IP address of the peer node. |
| static-pw |
Specifies the static pseudowire. |
| transmit label |
Specifies the pseudowire transmit label. |
| outgoing_pw_label |
Specifies the name of the egress label. |
| receive-label |
Specifies the static pseudowire receive label. |
| incoming_pw_label |
Specifies the name of the ingress label. |
N/A.
Use this command to change the labels of a statically configured Ethernet pseudowire for a VPWS that already exists. Either or both the outgoing (MPLS ingress) and incoming (MPLS egress) PW labels can be specified. The peer must be similarly configured with a static PW that has the reverse PW label mappings. Locally, the incoming_pw_label must be unique and is allocated out of the static label space. The outgoing_pw_label must match the peer‘s configured incoming PW label. The L2VPN can remain operational during the change; however, the PW goes down and comes back up.
The following command changes the VPWS label to "vpws1":
# configure l2vpn vpws vpws1 peer static-pw 1.1.1.202
This command was first available in ExtremeXOS 15.4.
This command is available on all platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
